Note: HOT300-C Heater Controller is sold separately: https://www.elmorlabs.com/product/elmorlabs-hot300-heater-controller/
- Heating power up to 240W (60W per zone, 10W per segment)
- Compatible with HOT300-C (not HOT-C)
- Dimensions (HOT-FLEX)
- 73 x 22 x 0.8 mm (6 segments each 12 mm)
- Dimensions (HOT-SPLIT)
- 42 x 52 x 1.6 mm
- Mounting holes (HOT-SPLIT)
- M2 37 x 47 mm
- HOT-SPLIT PCB
- 4x HOT-FLEX PCBs
- Cable for connecting Controller & Splitter 30 cm (13 pin black AWG22)
- 4x Cable for connecting Splitter & FLEX/Heater PCB 30 cm (4 pin black AWG22)
- Thermal pad for heater (100 x 100 x 2.5mm, 6 W/mK)
- 4x Standoffs M2 20+5 mm
- 4x Replacement thermistors
