uP9512r on Gigabyte 4090 gaming oc
anyone know where the sda and scl pads are on the 4090 gaming oc pcb.  I know its pins 34 and 35 on the controller.  do you just trace out from those pins to find a connection.  or do you have to go directly to the pins or resistors connected to the pins.  would love to do a volt mod and change the resistance between vref and refin but not comfortable yet starting on a 4090 haha and dealing with refadj to disable software voltage control
