Forum breadcrumbs - You are here:ForumEVC2: User projectsuP9512 on RTX 2070 Super
Hi,
I have a Gigabyte RTX 2070 Super which uses an uP9512 which I can connect to with the EVC 2 SX but it's locked.
Does anyone have a way to unlock it?
I have searched, but could not find how to unlock it.
Quote from istvanzb on 2022-06-11, 14:54
Hi,
Hello, normally the lock command is sent to the controller during POST (VBIOS initialization). This can be prevented by checking the "Lock bus" check box + Apply under I2Cx in the EVC2 software. The graphics card needs to be fully powered down to unlock the controller again.
Hello Jon,
Thank you, I'll try it. Can it be set permanently to unlocked? I guess no, because the vbios will lock it every time.
Thank you,
Istvan
Quote from istvanzb on 2022-06-11, 21:22
Hello Jon,
Thank you,
Istvan
hello, what pins do you use on the controller to connect the evc.  just trying to figure out if i can use the vc on the same controller on the 4090
