PMD ADC Details
Quote from shawn on 2022-05-27, 03:33Hi Jon,
We now have our CMSIS-DAP adapter so we can test new FW, if you have a new binary available.
Thanks,
Shawn
Edit: The red circled pads are for SWD, correct?
Hi Jon,
Thanks,
Shawn
Uploaded files:Quote from elmor on 2022-05-27, 14:49Quote from shawn on 2022-05-27, 03:33Hi Jon,
Thanks,
Shawn
Hello Shawn,
Yes correct. Actually SWD/SWC is also connected through the OLED header. The OLED itself may interfere with programming, so best to remove it first.
OLED header SCL = SWD, SDA = SWC. You can also power the PMD from the CMSIS-DAP by connecting OLED header 3.3V and GND. You probably separately have to wire reset to the MCU pin#6.
Firmware for test: https://1drv.ms/u/s!Atmpv-6qHr_61-V7UWlpNQwEIBrpWQ?e=6LP46a
Thanks,
Shawn
Hello Shawn,
Uploaded files:Quote from shawn on 2022-05-28, 07:37Thanks for the info + firmware.
Unfortunately I was not able to successfully flash firmware on the PMD even after double and triple checking all connections. I am going to try a different ARM CMSIS-DAP compliant debugger in the next few days.
Thanks,
Shawn
Thanks,
Shawn
Quote from shawn on 2022-06-04, 06:56Hi Jon,
I'm still not able to program our PMD. I scoped out the signals and clock / data / nreset do resemble something correct, and the red PMD LED does turn on briefly, but the SW tools indicate that no response was received from the device.
If I put in an order for 2-3 additional PMDs, is it possible to get the new firmware pre-flashed on them?
Thanks,
Shawn
Hi Jon,
Thanks,
Shawn
Quote from elmor on 2022-06-06, 18:04Quote from shawn on 2022-06-04, 06:56Hi Jon,
Thanks,
Shawn
Hello Shawn,
Ok it's supposed to be possible and works here with J-Link as long as reset signal is wired. Any newly ordered units will ship as the PMD-USB version, which both offers higher transfer rate (2 MBit/s) and firmware update capability as long as you're willing to talk to it using USB to PC instead of the previous I2C interface.
Thanks,
Shawn
Hello Shawn,
Quote from shawn on 2022-06-08, 04:52Hi Jon,
Good news - I was able to successfully erase / flash / verify (I think). I think my previous issue was that SWCLK was not held low after reset deassertion (so JTAG / SWD mode was not enabled). I was able to make it work with the following sequence:
- Hold SWCLK + Reset low manually.
- Release reset (leave floating).
- Release SWCLK.
- Flash.
Bad news - I still see the same issue with PMD.X.production_20220527_1330.bin. Here is a histogram, for reference (12V / 800mA load).
0000: 9884
0001: 2209
0002: 163
0003: 5
0004: 0
0005: 0
0006: 0
0007: 0
0008: 0
0009: 0
000a: 10
000b: 199
000c: 2370
000d: 13261
000e: 28846
000f: 27495
0010: 2560
0011: 489
0012: 35
0013: 1I'm pretty sure that I am actually flashing the new image - I'm using edbg in verbose mode, it reports each step as it goes along, and programming seems to take several seconds. Also I see traffic on the SWD lines when flashing.
Is it possible that the FW race condition still exists?
Thanks,
Shawn
Edit: The "Firmware Version" read over I2C reads 5 on the newly flashed PMD.
Hi Jon,
- Release SWCLK.
- Flash.
0000: 9884
0001: 2209
0002: 163
0003: 5
0004: 0
0005: 0
0006: 0
0007: 0
0008: 0
0009: 0
000a: 10
000b: 199
000c: 2370
000d: 13261
000e: 28846
000f: 27495
0010: 2560
0011: 489
0012: 35
0013: 1
Thanks,
Shawn
Quote from elmor on 2022-06-08, 09:02Quote from shawn on 2022-06-08, 04:52Hi Jon,
- Release SWCLK.
- Flash.
0000: 9884
0001: 2209
0002: 163
0003: 5
0004: 0
0005: 0
0006: 0
0007: 0
0008: 0
0009: 0
000a: 10
000b: 199
000c: 2370
000d: 13261
000e: 28846
000f: 27495
0010: 2560
0011: 489
0012: 35
Thanks,
Shawn
Hello Shawn,
Ok I'll have a look again. What was done now is that the value is latched when reading the lower byte of 0x80-0x8F registers, which one are you using for the above?
Ex:
1. Read 0x80 (updates latched value, returns latched PCIE1 Voltage low byte)
2. Read 0x81 (returns latched PCIE1 Voltage high byte)Also works to send CMD 0x80 and read 2 bytes.
- Release SWCLK.
- Flash.
0000: 9884
0001: 2209
0002: 163
0003: 5
0004: 0
0005: 0
0006: 0
0007: 0
0008: 0
0009: 0
000a: 10
000b: 199
000c: 2370
000d: 13261
000e: 28846
000f: 27495
0010: 2560
0011: 489
0012: 35
Thanks,
Shawn
Hello Shawn,
Ex:
Quote from shawn on 2022-06-09, 00:17Hi Jon,
I was using register 0x05/0x06 for PCIE1 current. It sounds like the new latching scheme only applies for regs 0x8X / 0x9X? I will try 0x82/0x83 instead and post back results!
Thanks,
Shawn
Edit: My initial results show that using 0x82 (rather than 0x05) reduces the number of error / mismatch cases dramatically (factor of ~50x). I will gather histogram data using a known current load later today.
It looks like the major source of this issue is now eliminated! As for the remaining error source, is it possible that the latched 12-bit value isn't updated atomically (e.g., ADC in in the process of writing latest conversion at the same time we do a load, so we get one "old" byte and one "new" byte)? Is it worth trying something like this for the latching?
// assuming something like uint16_t latched_val, volatile uint16_t *latest_adc.
do { latched_val = *latest_adc; } while (latched_val != *latest_adc);
Edit2: Here is the histogram for fixed 800mA load:
0000: 105
0001: 28
0002: 3
0003: 0
0004: 0
0005: 0
0006: 0
0007: 0
0008: 0
0009: 0
000a: 6
000b: 249
000c: 2753
000d: 15217
000e: 34184
000f: 32132
0010: 12296
0011: 2649
0012: 181As you can see, the error rate is > 50x lower than before, a big improvement.
FYI I am reading two bytes from 0x82 in this example.
Hi Jon,
Thanks,
Shawn
0000: 105
0001: 28
0002: 3
0003: 0
0004: 0
0005: 0
0006: 0
0007: 0
0008: 0
0009: 0
000a: 6
000b: 249
000c: 2753
000d: 15217
000e: 34184
000f: 32132
0010: 12296
0011: 2649
0012: 181
Quote from shawn on 2023-05-10, 06:19Hi Jon,
I would like to double check - is the register latching scheme for I2C 0x8X / 0x9X implemented in the latest shipping version of PMD-USB FW? We are considering to order several more units shortly and for a few reasons (mainly because we have already tested + validated the I2C interface), we still prefer the I2C interface rather than USB. Thanks.
Edit: Looking at the datasheet closer, I should have asked this question first: does the PMD-USB still support an I2C interface?
Hi Jon,
Quote from elmor on 2023-05-10, 11:19Quote from shawn on 2023-05-10, 06:19Hi Jon,
Hello Shawn,
The register latching is different for PMD-USB, much due to your feedback. Values are copied to a second buffer for sending over USB after an ADC update to prevent the above issue. Additionally there's a bootloader that allows for firmware updates on PMD-USB, meaning it's easier to patch this type of bug going forward.
Regarding the I2C interface, the PMD-USB does not support it by default. Depending on how important it is, I see two ways PMD-USB could be customized to support it. It would require flashing a modified version of the PMD firmware on it through the PMD-USB bootloader. Then the I2C interface could either be exposed using the OLED header (and lose OLED support) or you could remove the CH340N USB-to-Serial IC and solder the I2C wires directly to those pads (UART TX/RX pins are the same a previous SDA/SCL pins). The MCU used is the same except with double the flash memory meaning it's code compatible. If this would be a viable solution I can prototype it for you.
Hello Shawn,
