List of compatible motherboards
Quote from elmor on 2020-10-25, 10:40This product relies on an existing LPC header on the motherboard for TPM or debug. Later generation motherboards (X570, Z490) may have a "SPI_TPM" header which is not compatible.
Known compatible (header name)
- ASUS 970 Pro Gaming/AURA (TPM)
- ASUS Prime Z390-A (TPM)
- ASUS ROG Crosshair VI Hero (TPM)
- ASUS ROG Crosshair VII Hero (LPC_DEBUG)
- ASUS ROG Crosshair VIII Formula (unnamed header left of Node connector)
- ASUS ROG Maximus IX Apex (TPM)
- ASUS ROG Maximus X Apex (TPM)
- ASUS ROG Rampage VI Apex (TPM)
- ASUS ROG Strix B450-F Gaming (TPM)
- ASUS ROG Strix TRX40-XE Gaming (TPM)
- ASUS ROG Strix X470-F Gaming (TPM)
- ASUS ROG Strix Z390-E Gaming (TPM)
- ASUS ROG Strix Z390-F Gaming (TPM)
- ASUS ROG Strix Z390-H Gaming (TPM)
- ASUS ROG Strix Z490-A Gaming (DEBUG)
- ASUS ROG Zenith Extreme (TPM)
- ASUS ROG Zenith II Extreme (TPM)
- ASRock X570 Pro4 (TPMS1)
- Gigabyte B550 Aorus Pro (TPM)
- Gigabyte B550 Aorus Pro AX (TPM)
- Gigabyte B550I Aorus Pro AX (TPM)
- Gigabyte X570 Aorus Elite (TPM)
- Gigabyte X570 Aorus Elite Wifi (TPM)
- Gigabyte X570 Aorus Master (TPM)
- Gigabyte X570 Aorus Pro (TPM)
- Gigabyte X570 Aorus Pro Wifi (TPM)
- Gigabyte X570 Aorus Ultra (TPM)
- Gigabyte X570 Aorus Xtreme (TPM)
- Gigabyte X570 Gaming X (TPM)
- Gigabyte X570 UD (TPM)
- Gigabyte X570 I Aorus Pro Wifi (TPM)
- Gigabyte Z390 Gaming X (TPM)
- Gigabyte Z390 UD (TPM)
- MSI B450M Mortar Max (JTMP1)
- MSI MPG Z490M Gaming Edge Wifi (JTPM1)
- MSI X570 Tomahawk Wi-Fi (JTPM1)
- MSI X570-A Pro (JTPM1)
Known not compatible
- Any Gigabyte B460/H470/Z490
- Any Asus B550/X570
- Asrock Phantom Gaming-ITX/ax
- ASUS ROG Maximus XI Apex
- ASUS ROG Maximus XII Apex
- ASUS ROG Strix Z390-I
- ASUS Prime Z390-P (no header, only soldering spots)
- MSI MAG B550 Tomahawk (SPI TPM header)
- MSI MPG B550I Gaming Edge Wifi
Quote from Deleted user on 2020-12-01, 00:40Is there an update of that list available (e.g. for Gigabyte X570 boards)?
Quote from Deleted user on 2020-12-05, 23:15Are port 80 debug/ POST codes generally not provided anymore with the SPI bus, or is this a limitation of e.g. the chip on the module?
Quote from malmoeoe on 2020-12-21, 01:06Hi! I´ve tested the P80DB1L with the MSI Z390 Tomahawk and the X470 Gaming Pro Carbon. With neither of them the Board works - it´s always Code "00".
Quote from elmor on 2020-12-22, 23:53Quote from malmoeoe on 2020-12-21, 01:06Hi! I´ve tested the P80DB1L with the MSI Z390 Tomahawk and the X470 Gaming Pro Carbon. With neither of them the Board works - it´s always Code "00".
Hello, do you have pictures of how it's connected on both the P80DB1L side and the motherboard side?
Quote from Rob999 on 2020-12-05, 23:15Are port 80 debug/ POST codes generally not provided anymore with the SPI bus, or is this a limitation of e.g. the chip on the module?
On newer Intel platforms from certain vendors they have changed from LPC to eSPI as the primary on-board bus. It seems there are two of these eSPI lines, one going to the SIO + EC (if any) and one going to the SPI_TPM header + BIOS chip. The debug data is sent on the bus going to the SIO + EC and so far I've not seen any board expose a header for it. Additionally the current debug cards only work with a LPC bus so even if there was a header the debug card would need a new version.
Quote from malmoeoe on 2020-12-23, 06:04Quote from elmor on 2020-12-22, 23:53Quote from malmoeoe on 2020-12-21, 01:06Hi! I´ve tested the P80DB1L with the MSI Z390 Tomahawk and the X470 Gaming Pro Carbon. With neither of them the Board works - it´s always Code "00".
Hi!
Yes, of course - there you go. Please let me know, if you need more pictures or some specific details.
Hi!
Quote from elmor on 2020-12-23, 14:02Quote from malmoeoe on 2020-12-23, 06:04Hi!
Thank you for the pictures. It appears that both the purple and blue wires are missing from your cable ( https://www.elmorlabs.com/index.php/2018-09-23/p80db1l-port-80-lpc-debug-card/ ) . You can move those wires from other vendor cables if you want to try it. I can also send you a new replacement cable.
Quote from malmoeoe on 2020-12-24, 06:16I just compared the wireing of the long cable with the short one - you´re absolutely right. The blue and purple wire is missing. I´ve never checked that.. probably my bad. With the short cable it´s working fine - tested with the MSI Z390 Tomahawk - so you can add this board to your list.
It might be more comfortable for me, if you send a replacement cable, but i think it´s definetly irresponsible for economical reasons. But thank you very much for your offering! I really appreciate your support.
Have you any tips for extracting these small wires/pins?
Quote from elmor on 2021-01-03, 15:08Quote from malmoeoe on 2020-12-24, 06:16I just compared the wireing of the long cable with the short one - you´re absolutely right. The blue and purple wire is missing. I´ve never checked that.. probably my bad. With the short cable it´s working fine - tested with the MSI Z390 Tomahawk - so you can add this board to your list.
Ok let me know if you change your mind and I'll arrange it. A small thin flat screw driver should work ok for lifting the plastic flaps that hold the crimps locked in the connector. After lifting it about 1-2 mm you should be able to pull out the wire. Re-inserting it should not require any work, just push it in there and it should be locked in place.
