KTH Q & A
Ask your questions about the product in this thread.
@elmor
I`ve probs with my KTH, the reading Temps are all wron. Now I`ve connectet it to EVC2 and wanted change done factory reset.
Can you please send me the values for Zero-Bias, Gain ant ThOffset?
Hello, factory calibration values for your unit as below. I think you can also change the Calibration Profile to Factory to get these?
TC1
Zero-bias: 32777
Gain: 802
ThOffset: -28
TC2
Zero-bias: 32761
Gain: 802
ThOffset: 28
sergmann has reacted to this post.
sergmann
nothing helps :(.
TC1 doesn`t work correct. Shows me 22,6-22,7 °c and don`t change the temps if I put the probe into LN2
Are all other settings correcht?
Quote from sergmann on 2021-04-18, 05:47
nothing helps :(.
Can you join Discord so I can help you in real time?
