I can't control a temp for the HOT Heater Controller.
Quote from littleboy on 2021-07-02, 11:07recently, I bought the HOT Heater Controller and EVC2SX.
I can't control the temp.
zone 2 raise 200 degree. other zone can't control.
I tried to set a temp by the EVC2SX controller software. it doesn't work. but, the temp monitoring works as well.
Does the controller part of HOT Heater Controller has broken?
How do i fix this issue?
Please check it.
Please check it.
Quote from elmor on 2021-07-02, 12:17Hello, it sounds like you've received a faulty unit. I suspect the MOSFET for zone 2 on the HOT-C board is bad and can't turn off. I'm not sure if you would be able to replace this part yourself? If you want to try, I can provide further instructions. Either way, I will arrange a new one to be sent to you. What was your order number?
