Soldering points for Gainward RTX 5090 Phantom
Quote from GotSomeMilk on 2023-09-04, 00:23Here are the soldering points to connect the EVC2 to a Gainward RTX 5090.
The black cable [GND] is 28 AWG; the white [SDA] and green [SCL] cables are 34 AWG.
Works perfectly on my Gainward RTX 5090.
This guide is provided “as is” without warranty of any kind. I am not liable for any hardware damage, software issues, or data loss resulting from its use.
https://imgur.com/a/aQvI39O
https://imgur.com/a/iYgLEmu
[OLD POST]
Hi,
I finally got my EVC2. I took some pictures of the PCB to find the solder points. I don't see any I2C header points on the board. So only solution is to solder directly to the controller (I guess). GPU voltage is managed by uP9512U controller. According to the datasheet for that IC, Pin 34 is SDA, Pin 35 is SCL.
For the ground I can basically chose whatever ground point I can find no? Basically whatever point which has next to zero resistance once measured versus the screw holes ?
I just want to be sure about this before I blow up a 1900 euros GPU. Cooling will taken care of by huge Mora-3 rad 🙂
Thx for any help
[OLD POST]
Hi,
Thx for any help
Quote from James Tiller on 2024-07-16, 03:28How did this go?
Were these the correct solder points for you ?
How did this go?
Quote from GotSomeMilk on 2024-07-18, 03:40It worked fine. I can confirm the solder points above. It detects the EVC2 without trouble. Soldering points are very small and you will need to use smaller ones.
Honestly, I don't think it's worth it. I pushed nearly 1.25v and the GPU simply doesn't scale. After 1.15v it's already over. Only power consumption will keep increasing.
Quote from kryptonfly on 2024-12-22, 23:06Hey, I need help, I soldered the black to the ground, the green to SCL and the white to SDA, I can read up9512 controller but I can't write. How do you do and why you put the black as SCL ? Thank you !
EDIT : I figured it out, I used the Galax bios and it was locked, I switched to the Asus XOC bios and it works !
Quote from JolieKeva on 2025-03-25, 17:43Quote from head soccer on 2024-07-18, 03:40It worked fine. I can confirm the solder points above. It detects the EVC2 without trouble. Soldering points are very small and you will need to use smaller ones.
Thank you very much for all your work and this fix, keep up the good work!
