Can I use the EVC2 to read/write to a DIP8?
Quote from learn12 on 2023-06-16, 05:32Does this device only work with the provided software or does it also work with
flashromas well for example?I have read a couple forum posts about the software having issues with flashing ROMs less than the previous BIOS or something? I have an Asus KGPE-D16 with a DIP8 chip I'd like to flash with Libreboot.
Edit: I have a ch341a_spi programmer that's been modified to 3.3v but even with the 1.8v adapter I can't read the chip. So the EVC2 DIP8 adapter seemed perfect.
Thanks!
Does this device only work with the provided software or does it also work with flashrom as well for example?
Thanks!
Quote from elmor on 2023-06-28, 19:03Hello. It only works with the provided software. The DIP8 adapter can also be used with something like a CH341A programmer assuming you have the pin adapter which is included with the SOIC8 test clip for example.
