Voltmeter 4-digit blue 0.4″ *discontinued*
$10.00
Out of stock
SKU: VOLTMETER_4DIG_040IN_BLUE Category:
Simple voltmeter for project integration with high accuracy. Expected availability early May 2020.
  • 4-digit 7-segment display
  • Separate supply and sense wires
  • Supply voltage 3.8 V to 30 V
  • Supply current <= 20 mA
  • Sense voltage 0V to 30 V
  • General accuracy 0.1% +/- 2 digits
  • Update rate 3 Hz
  • 3 decimals below 10 V, 2 decimals above
  • Potentiometer for calibration
  • Dimensions 48.5mm*16mm*10mm
  • Display size 40.5mm * 16mm
  • M2.5 hole pattern 44.5 mm * 12 mm
Typical performance
Vin = 12.20 V
