Voltmeter 3-digit blue 0.36″ (pack of 3) *discontinued*
$15.00
Out of stock
SKU: VOLTMETER_3DIG_036IN_BLUE_PACKx3 Category:
Simple voltmeter for project integration. Expected availability early May 2020.
  • 3-digit 7-segment display
  • Separate supply and sense wires
  • Supply voltage 4.5 V to 30 V
  • Supply current <= 15 mA
  • Sense voltage 0V to 32 V
  • General accuracy 0.5% +/- 2 digits
  • Update rate 3 Hz
  • 3 decimal digits below 10 V, 2 decimal digits above
  • Potentiometer for calibration
  • Dimensions 31.5 mm*14.1 mm*12 mm
  • Display size 22.6 mm*14 mm
  • M2.5 hole pattern 26.8 mm*10.1 mm
Typical performance
Vin = 12.32 V
