This cable can be used with PMD and PMD-USB for supporting graphics cards with the PCI-E 5.0/ATX 3.0 12VHPWR connector. It requires two 8-pin outputs to be used on the PMD, both PCI-E and EPS output channels are supported. The cable length is 50 cm and the power specification is 600W. It’s recommended to use either 3x PCI-E 8-pin or 2x EPS connectors with this cable to prevent overloading your PSU cable.
