The ElmorLabs OC Panel (OverClocking Panel) is tailored to meet the needs of overclockers seeking advanced functionality, featuring a specialized thermometer function capable of supporting cryogenic temperatures. With two thermocouple inputs, users can effectively monitor temperature levels, even in challenging cooling conditions. Additionally, the OC Panel offers three differential voltage measurements for precise adjustment of voltage settings. Conveniently placed power and reset buttons provide easy access to essential controls for seamless adjustments and system management. Depending on motherboard compatibility, the OC Panel integrates additional functionalities such as reading post codes and activating functions like base clock adjustment, slow mode, safe boot, and retry functions, providing users with enhanced flexibility in their overclocking endeavors. In collaboration with ASUS their specialized software offering various frequency and voltage controls both globally and per core together with monitoring of frequencies, voltages and temperatures. With its comprehensive feature set and user-friendly design, the ElmorLabs OC Panel is an ideal choice for enthusiasts looking to optimize their hardware performance.
Specifications
- 2.4″ White OLED with UI on device
- USB Type-C header (power and data)
- 2x Thermocouple inputs (K-type, -261.3°C to 366.8 °C)
- JOCP1 header (for motherboard connection)
- JDBG1 header (serial post code)
- JSLOW1 header (slow mode) and on-board button
- JRST1 header (front-panel reset) and on-board button
- JPWR1 header (front-panel power) and on-board button
- Built-in USB bootloader for firmware updating
- 3D Printed case with acrylic sheet and mounting accessories
- Kick stand
- Dimensions 100 x 100 mm (without case)
Included accessories
- USB Type-A to USB Type-C cable 1M
- OCP Type-A (ASUS RSVD_4) Cable 50 cm
- OCP Type-M (MSI JDASH1) Cable 50 cm
- 3x 2-pin 2.54mm male to male cable 50 cm
- Pin jumper 2-pin 2.54mm
- 2x Thermocouple K-type 1.5M
Motherboard support list (full function)
- ASUS ROG Maximus Z790 Apex Encore
