ElmorLabs HOT300 Heater Generic & GPU Backplate
$25.00
Available on backorder
SKU: HOT300-B-GEN Category:
Note: HOT300-C Heater Controller is sold separately: https://www.elmorlabs.com/product/elmorlabs-hot300-heater-controller/
Introducing the new and improved heater backplate, designed to fit most use cases including motherboards and graphics cards! Our backplate is improved to reduce interference with on-board parts and custom backplates. The heater controller, which is necessary for operation, is sold separately.
  • Heating power up to 288W
  • Dimensions (HOT300-B-GEN)
    • 104 x 96 x 2.4 mm
  • Mounting holes (HOT300-B-GEN)
    • AM2/AM3/AM4
    • Socket 115x
    • Socket 1700
    • Socket 1366/2066
    • Nvidia 20-series (52.82 x 52.82 mm, 70.5 x 70.5 mm)
    • Nvidia 30-series (59 x 67.5 mm)
    • 43 x 43 mm
    • 51 x 61 mm
    • 53 x 53 mm
    • 58.4 x 58.4 mm
    • 64 x 64 mm
  • HOT300-B-GEN Backplate
  • Cable for connecting Controller & Backplate 30 cm (Black AWG22)
  • Thermal pad for backplate (100 x 100 x 2.5 mm, 6 W/mK)
  • Thermal pad for backplate (100 x 100 x 8.0 mm, 6 W/mK)
  • 4x Spare Thermistors 10 kΩ 1% B3380 0603
