The DERULER project is currently discontinued, thank you for your interest!
This collaboration between der8auer, ElmorLabs and PCBWay is intended to introduce you to the world of electrical engineering through soldering, circuit design and programming. It’s an electronics project that consists of a PCB ruler with a functional circuit on it that’s enabled by soldering the included components. The microcontroller on the board can be programmed with any of the available examples or you can write your own application for it.
We hope you will enjoy this experience and proceed to make your own electronics project at some point. If you need help with anything feel free to check out the dedicated ElmorLabs forum section or Discord.
Note: In order to complete this project you will need a soldering iron and a computer.
- DERULER PCB Ruler
- DERULER electrical components (integrated circuits, resistors, capacitors, connectors)
- ST-Link V2 USB Programmer
- Programming Cable IDC 2×5-pin
