Multiple gpu mounting locations
Quote from dragon23367 on 2021-08-03, 20:54Hi elmor ive recently purchased your evc2sx, looking forward to it arriving.
edit: first card im looking to i2c into is a zotac 3070ti amp holo 8gb gddr6x.
after a few days of researching ive found mounting locations for sda/sdl/gnd, they are through hole mounting points conveniently left over, picture provided.
the only chip i can see on the board that is compatible with the EVC2SX is the UP9512R voltage controller used for the GPU VRM (could you clarify if the 'R' on the model matters it terms of compatibility with the EVC2SX?)
my next step is understanding the chip registers and how they influence the card, im looking to increase efficiency of the power stages (reducing frequency / voltage)
i can see the registers on the datasheet, so thats my next place to search for clues.
thanks, any help is appreciated
Uploaded files:Quote from elmor on 2021-08-05, 21:40Quote from dragon23367 on 2021-08-03, 20:54Hi elmor ive recently purchased your evc2sx, looking forward to it arriving.
Hello,
You can check the uP9512.xml file under the I2C_DEVICES folder of the EVC2 software for guidance on how some of the registers work.
BR,
Jon
Hello,
BR,
Jon
Quote from dragon23367 on 2021-08-19, 15:37Hello,
BR,
JonHi elmor thanks for the reply, ive recieved my EVC2SX, i hooked up the i2c to the mounting points on my card but no controllers were detected, so i dumped the bus,
[spoiler title="3070ti i2c dump"]
EVC2 1.0.1.7 I2C DUMP
Bus=1
AddressList=4F--- CSV DATA START ---
Address,Cmd,Len,Result,Data
4F,00,1,True,1C
4F,01,1,True,00
4F,02,1,True,00
4F,03,1,True,00
4F,04,1,True,00
4F,05,1,True,00
4F,06,1,True,00
4F,07,1,True,00
4F,08,1,True,00
4F,09,1,True,00
4F,0A,1,True,00
4F,0B,1,True,00
4F,0C,1,True,00
4F,0D,1,True,00
4F,0E,1,True,00
4F,0F,1,True,00
4F,10,1,True,00
4F,11,1,True,58
4F,12,1,True,00
4F,13,1,True,5C
4F,14,1,True,40
4F,15,1,True,00
4F,16,1,True,00
4F,17,1,True,00
4F,18,1,True,00
4F,19,1,True,00
4F,1A,1,True,00
4F,1B,1,True,00
4F,1C,1,True,00
4F,1D,1,True,00
4F,1E,1,True,00
4F,1F,1,True,00
4F,20,1,True,00
4F,21,1,True,00
4F,22,1,True,00
4F,23,1,True,00
4F,24,1,True,00
4F,25,1,True,00
4F,26,1,True,00
4F,27,1,True,00
4F,28,1,True,00
4F,29,1,True,00
4F,2A,1,True,00
4F,2B,1,True,00
4F,2C,1,True,00
4F,2D,1,True,00
4F,2E,1,True,00
4F,2F,1,True,00
4F,30,1,True,00
4F,31,1,True,00
4F,32,1,True,00
4F,33,1,True,00
4F,34,1,True,00
4F,35,1,True,00
4F,36,1,True,00
4F,37,1,True,00
4F,38,1,True,00
4F,39,1,True,00
4F,3A,1,True,00
4F,3B,1,True,00
4F,3C,1,True,00
4F,3D,1,True,00
4F,3E,1,True,00
4F,3F,1,True,00
4F,40,1,True,00
4F,41,1,True,00
4F,42,1,True,00
4F,43,1,True,00
4F,44,1,True,00
4F,45,1,True,00
4F,46,1,True,00
4F,47,1,True,00
4F,48,1,True,80
4F,49,1,True,00
4F,4A,1,True,00
4F,4B,1,True,00
4F,4C,1,True,00
4F,4D,1,True,00
4F,4E,1,True,00
4F,4F,1,True,00
4F,50,1,True,04
4F,51,1,True,04
4F,52,1,True,04
4F,53,1,True,04
4F,54,1,True,04
4F,55,1,True,04
4F,56,1,True,04
4F,57,1,True,04
4F,58,1,True,04
4F,59,1,True,04
4F,5A,1,True,04
4F,5B,1,True,04
4F,5C,1,True,04
4F,5D,1,True,04
4F,5E,1,True,04
4F,5F,1,True,04
4F,60,1,True,9A
4F,61,1,True,A1
4F,62,1,True,DE
4F,63,1,True,10
4F,64,1,True,82
4F,65,1,True,24
4F,66,1,True,DA
4F,67,1,True,19
4F,68,1,True,53
4F,69,1,True,16
4F,6A,1,True,05
4F,6B,1,True,00
4F,6C,1,True,00
4F,6D,1,True,00
4F,6E,1,True,00
4F,6F,1,True,00
4F,70,1,True,00
4F,71,1,True,00
4F,72,1,True,00
4F,73,1,True,5E
4F,74,1,True,00
4F,75,1,True,00
4F,76,1,True,00
4F,77,1,True,00
4F,78,1,True,00
4F,79,1,True,00
4F,7A,1,True,00
4F,7B,1,True,00
4F,7C,1,True,00
4F,7D,1,True,00
4F,7E,1,True,00
4F,7F,1,True,00
4F,80,1,True,00
4F,81,1,True,00
4F,82,1,True,00
4F,83,1,True,00
4F,84,1,True,00
4F,85,1,True,00
4F,86,1,True,00
4F,87,1,True,00
4F,88,1,True,00
4F,89,1,True,00
4F,8A,1,True,00
4F,8B,1,True,00
4F,8C,1,True,00
4F,8D,1,True,00
4F,8E,1,True,00
4F,8F,1,True,00
4F,90,1,True,00
4F,91,1,True,00
4F,92,1,True,00
4F,93,1,True,00
4F,94,1,True,00
4F,95,1,True,00
4F,96,1,True,00
4F,97,1,True,00
4F,98,1,True,00
4F,99,1,True,00
4F,9A,1,True,00
4F,9B,1,True,00
4F,9C,1,True,00
4F,9D,1,True,00
4F,9E,1,True,00
4F,9F,1,True,00
4F,A0,1,True,00
4F,A1,1,True,00
4F,A2,1,True,00
4F,A3,1,True,00
4F,A4,1,True,00
4F,A5,1,True,00
4F,A6,1,True,00
4F,A7,1,True,00
4F,A8,1,True,00
4F,A9,1,True,00
4F,AA,1,True,00
4F,AB,1,True,00
4F,AC,1,True,00
4F,AD,1,True,00
4F,AE,1,True,00
4F,AF,1,True,00
4F,B0,1,True,00
4F,B1,1,True,00
4F,B2,1,True,00
4F,B3,1,True,00
4F,B4,1,True,00
4F,B5,1,True,00
4F,B6,1,True,00
4F,B7,1,True,00
4F,B8,1,True,00
4F,B9,1,True,00
4F,BA,1,True,00
4F,BB,1,True,00
4F,BC,1,True,00
4F,BD,1,True,00
4F,BE,1,True,00
4F,BF,1,True,00
4F,C0,1,True,00
4F,C1,1,True,00
4F,C2,1,True,00
4F,C3,1,True,00
4F,C4,1,True,00
4F,C5,1,True,00
4F,C6,1,True,00
4F,C7,1,True,00
4F,C8,1,True,00
4F,C9,1,True,00
4F,CA,1,True,00
4F,CB,1,True,00
4F,CC,1,True,00
4F,CD,1,True,00
4F,CE,1,True,00
4F,CF,1,True,00
4F,D0,1,True,00
4F,D1,1,True,00
4F,D2,1,True,00
4F,D3,1,True,00
4F,D4,1,True,00
4F,D5,1,True,00
4F,D6,1,True,00
4F,D7,1,True,00
4F,D8,1,True,00
4F,D9,1,True,00
4F,DA,1,True,00
4F,DB,1,True,00
4F,DC,1,True,00
4F,DD,1,True,00
4F,DE,1,True,00
4F,DF,1,True,00
4F,E0,1,True,00
4F,E1,1,True,00
4F,E2,1,True,00
4F,E3,1,True,00
4F,E4,1,True,00
4F,E5,1,True,00
4F,E6,1,True,00
4F,E7,1,True,00
4F,E8,1,True,00
4F,E9,1,True,00
4F,EA,1,True,00
4F,EB,1,True,00
4F,EC,1,True,00
4F,ED,1,True,00
4F,EE,1,True,00
4F,EF,1,True,00
4F,F0,1,True,00
4F,F1,1,True,00
4F,F2,1,True,00
4F,F3,1,True,00
4F,F4,1,True,00
4F,F5,1,True,00
4F,F6,1,True,00
4F,F7,1,True,00
4F,F8,1,True,00
4F,F9,1,True,00
4F,FA,1,True,00
4F,FB,1,True,00
4F,FC,1,True,00
4F,FD,1,True,10
4F,FE,1,True,DE
4F,FF,1,True,01[/spoiler]
i tried to manually add the UP9512, no controllers was found on all address', i knew it wouldnt of been that easy so i located the SDA, SDL, GND mouting points next to the controller itself.
aha success! the voltage controller was found, but now another hurdle has been reached! the gpu will no let me unlock the controller, ive tried shorting sda/sdl on reset untill i reach windows and still no luck, argh this is frustrating me.
this is a dump of the UP9512 after i had successfully connected.
[spoiler title=""]
Bus=1
AddressList=25--- CSV DATA START ---
25,00,8,True,759999130F1B29FF
25,01,8,True,31759999130F1B29
25,02,8,True,1031759999130F1B
25,03,8,True,001031759999130F
25,04,8,True,0000103175999913
25,05,8,True,0000001031759999
25,06,8,True,8800000010317599
25,07,8,True,8888000000103175
25,08,8,True,8488880000001031
25,09,8,True,4484888800000010
25,0A,8,True,4444848888000000
25,0B,8,True,BC44448488880000
25,0C,8,True,3CBC444484888800
25,0D,8,True,3C3CBC4444848888
25,0E,8,True,3C3C3CBC44448488
25,0F,8,True,3C3C3C3CBC444484
25,10,8,True,3C3C3C3C3CBC4444
25,11,8,True,3C3C3C3C3C3CBC44
25,12,8,True,3C3C3C3C3C3C3CBC
25,13,8,True,003C3C3C3C3C3C3C
25,14,8,True,00003C3C3C3C3C3C
25,15,8,True,0000003C3C3C3C3C
25,16,8,True,000000003C3C3C3C
25,17,8,True,BB000000003C3C3C
25,18,8,True,BBBB000000003C3C
25,19,8,True,BBBBBB000000003C
25,1A,8,True,BBBBBBBB00000000
25,1B,8,True,8EBBBBBBBB000000
25,1C,8,True,008EBBBBBBBB0000
25,1D,8,True,1B008EBBBBBBBB00
25,1E,8,True,FE1B008EBBBBBBBB
25,1F,8,True,00FE1B008EBBBBBB
25,20,8,True,0000FE1B008EBBBB
25,21,8,True,2B0000FE1B008EBB
25,22,8,True,032B0000FE1B008E
25,23,8,True,20032B0000FE1B00
25,24,8,True,0020032B0000FE1B
25,25,8,True,0A0020032B0000FE
25,26,8,True,460A0020032B0000
25,27,8,True,07460A0020032B00
25,28,8,True,F007460A0020032B
25,29,8,True,98F007460A002003
25,2A,8,True,0098F007460A0020
25,2B,8,True,040098F007460A00
25,2C,8,True,26040098F007460A
25,2D,8,True,FF26040098F00746
25,2E,8,True,00FF26040098F007
25,2F,8,True,0000FF26040098F0
25,30,8,True,020000FF26040098
25,31,8,True,2C020000FF260400
25,32,8,True,872C020000FF2604
25,33,8,True,FF872C020000FF26
25,34,8,True,07FF872C020000FF
25,35,8,True,0F07FF872C020000
25,36,8,True,0A0F07FF872C0200
25,37,8,True,040A0F07FF872C02
25,38,8,True,FF040A0F07FF872C
25,39,8,True,FFFF040A0F07FF87
25,3A,8,True,FFFFFF040A0F07FF
25,3B,8,True,FFFFFFFF040A0F07
25,3C,8,True,FFFFFFFFFF040A0F
25,3D,8,True,FFFFFFFFFFFF040A
25,3E,8,True,FFFFFFFFFFFFFF04
25,3F,8,True,FFFFFFFFFFFFFFFF
25,40,8,True,FFFFFFFFFFFFFFFF
25,41,8,True,FFFFFFFFFFFFFFFF
25,42,8,True,FFFFFFFFFFFFFFFF
25,43,8,True,FFFFFFFFFFFFFFFF
25,44,8,True,FFFFFFFFFFFFFFFF
25,45,8,True,FFFFFFFFFFFFFFFF
25,46,8,True,FFFFFFFFFFFFFFFF
25,47,8,True,FFFFFFFFFFFFFFFF
25,48,8,True,FFFFFFFFFFFFFFFF
25,49,8,True,FFFFFFFFFFFFFFFF
25,4A,8,True,FFFFFFFFFFFFFFFF
25,4B,8,True,FFFFFFFFFFFFFFFF
25,4C,8,True,FFFFFFFFFFFFFFFF
25,4D,8,True,FFFFFFFFFFFFFFFF
25,4E,8,True,FFFFFFFFFFFFFFFF
25,4F,8,True,FFFFFFFFFFFFFFFF
25,50,8,True,FFFFFFFFFFFFFFFF
25,51,8,True,FFFFFFFFFFFFFFFF
25,52,8,True,FFFFFFFFFFFFFFFF
25,53,8,True,FFFFFFFFFFFFFFFF
25,54,8,True,FFFFFFFFFFFFFFFF
25,55,8,True,FFFFFFFFFFFFFFFF
25,56,8,True,FFFFFFFFFFFFFFFF
25,57,8,True,FFFFFFFFFFFFFFFF
25,58,8,True,FFFFFFFFFFFFFFFF
25,59,8,True,FFFFFFFFFFFFFFFF
25,5A,8,True,FFFFFFFFFFFFFFFF
25,5B,8,True,FFFFFFFFFFFFFFFF
25,5C,8,True,FFFFFFFFFFFFFFFF
25,5D,8,True,FFFFFFFFFFFFFFFF
25,5E,8,True,FFFFFFFFFFFFFFFF
25,5F,8,True,FFFFFFFFFFFFFFFF
25,60,8,True,FFFFFFFFFFFFFFFF
25,61,8,True,FFFFFFFFFFFFFFFF
25,62,8,True,FFFFFFFFFFFFFFFF
25,63,8,True,FFFFFFFFFFFFFFFF
25,64,8,True,FFFFFFFFFFFFFFFF
25,65,8,True,FFFFFFFFFFFFFFFF
25,66,8,True,FFFFFFFFFFFFFFFF
25,67,8,True,FFFFFFFFFFFFFFFF
25,68,8,True,FFFFFFFFFFFFFFFF
25,69,8,True,FFFFFFFFFFFFFFFF
25,6A,8,True,FFFFFFFFFFFFFFFF
25,6B,8,True,FFFFFFFFFFFFFFFF
25,6C,8,True,FFFFFFFFFFFFFFFF
25,6D,8,True,FFFFFFFFFFFFFFFF
25,6E,8,True,FFFFFFFFFFFFFFFF
25,6F,8,True,FFFFFFFFFFFFFFFF
25,70,8,True,FFFFFFFFFFFFFFFF
25,71,8,True,FFFFFFFFFFFFFFFF
25,72,8,True,FFFFFFFFFFFFFFFF
25,73,8,True,FFFFFFFFFFFFFFFF
25,74,8,True,FFFFFFFFFFFFFFFF
25,75,8,True,FFFFFFFFFFFFFFFF
25,76,8,True,FFFFFFFFFFFFFFFF
25,77,8,True,FFFFFFFFFFFFFFFF
25,78,8,True,FFFFFFFFFFFFFFFF
25,79,8,True,FFFFFFFFFFFFFFFF
25,7A,8,True,FFFFFFFFFFFFFFFF
25,7B,8,True,FFFFFFFFFFFFFFFF
25,7C,8,True,FFFFFFFFFFFFFFFF
25,7D,8,True,FFFFFFFFFFFFFFFF
25,7E,8,True,FFFFFFFFFFFFFFFF
25,7F,8,True,FFFFFFFFFFFFFFFF
25,80,8,True,FFFFFFFFFFFFFFFF
25,81,8,True,FFFFFFFFFFFFFFFF
25,82,8,True,FFFFFFFFFFFFFFFF
25,83,8,True,FFFFFFFFFFFFFFFF
25,84,8,True,FFFFFFFFFFFFFFFF
25,85,8,True,FFFFFFFFFFFFFFFF
25,86,8,True,FFFFFFFFFFFFFFFF
25,87,8,True,FFFFFFFFFFFFFFFF
25,88,8,True,FFFFFFFFFFFFFFFF
25,89,8,True,FFFFFFFFFFFFFFFF
25,8A,8,True,FFFFFFFFFFFFFFFF
25,8B,8,True,FFFFFFFFFFFFFFFF
25,8C,8,True,FFFFFFFFFFFFFFFF
25,8D,8,True,FFFFFFFFFFFFFFFF
25,8E,8,True,FFFFFFFFFFFFFFFF
25,8F,8,True,FFFFFFFFFFFFFFFF
25,90,8,True,FFFFFFFFFFFFFFFF
25,91,8,True,FFFFFFFFFFFFFFFF
25,92,8,True,FFFFFFFFFFFFFFFF
25,93,8,True,FFFFFFFFFFFFFFFF
25,94,8,True,FFFFFFFFFFFFFFFF
25,95,8,True,FFFFFFFFFFFFFFFF
25,96,8,True,FFFFFFFFFFFFFFFF
25,97,8,True,FFFFFFFFFFFFFFFF
25,98,8,True,FFFFFFFFFFFFFFFF
25,99,8,True,FFFFFFFFFFFFFFFF
25,9A,8,True,FFFFFFFFFFFFFFFF
25,9B,8,True,FFFFFFFFFFFFFFFF
25,9C,8,True,FFFFFFFFFFFFFFFF
25,9D,8,True,FFFFFFFFFFFFFFFF
25,9E,8,True,FFFFFFFFFFFFFFFF
25,9F,8,True,FFFFFFFFFFFFFFFF
25,A0,8,True,FFFFFFFFFFFFFFFF
25,A1,8,True,FFFFFFFFFFFFFFFF
25,A2,8,True,FFFFFFFFFFFFFFFF
25,A3,8,True,FFFFFFFFFFFFFFFF
25,A4,8,True,FFFFFFFFFFFFFFFF
25,A5,8,True,FFFFFFFFFFFFFFFF
25,A6,8,True,FFFFFFFFFFFFFFFF
25,A7,8,True,FFFFFFFFFFFFFFFF
25,A8,8,True,FFFFFFFFFFFFFFFF
25,A9,8,True,FFFFFFFFFFFFFFFF
25,AA,8,True,FFFFFFFFFFFFFFFF
25,AB,8,True,FFFFFFFFFFFFFFFF
25,AC,8,True,FFFFFFFFFFFFFFFF
25,AD,8,True,FFFFFFFFFFFFFFFF
25,AE,8,True,FFFFFFFFFFFFFFFF
25,AF,8,True,FFFFFFFFFFFFFFFF
25,B0,8,True,FFFFFFFFFFFFFFFF
25,B1,8,True,FFFFFFFFFFFFFFFF
25,B2,8,True,FFFFFFFFFFFFFFFF
25,B3,8,True,FFFFFFFFFFFFFFFF
25,B4,8,True,FFFFFFFFFFFFFFFF
25,B5,8,True,FFFFFFFFFFFFFFFF
25,B6,8,True,FFFFFFFFFFFFFFFF
25,B7,8,True,FFFFFFFFFFFFFFFF
25,B8,8,True,FFFFFFFFFFFFFFFF
25,B9,8,True,FFFFFFFFFFFFFFFF
25,BA,8,True,FFFFFFFFFFFFFFFF
25,BB,8,True,FFFFFFFFFFFFFFFF
25,BC,8,True,FFFFFFFFFFFFFFFF
25,BD,8,True,FFFFFFFFFFFFFFFF
25,BE,8,True,FFFFFFFFFFFFFFFF
25,BF,8,True,FFFFFFFFFFFFFFFF
25,C0,8,True,FFFFFFFFFFFFFFFF
25,C1,8,True,FFFFFFFFFFFFFFFF
25,C2,8,True,FFFFFFFFFFFFFFFF
25,C3,8,True,FFFFFFFFFFFFFFFF
25,C4,8,True,FFFFFFFFFFFFFFFF
25,C5,8,True,FFFFFFFFFFFFFFFF
25,C6,8,True,FFFFFFFFFFFFFFFF
25,C7,8,True,FFFFFFFFFFFFFFFF
25,C8,8,True,FFFFFFFFFFFFFFFF
25,C9,8,True,FFFFFFFFFFFFFFFF
25,CA,8,True,FFFFFFFFFFFFFFFF
25,CB,8,True,FFFFFFFFFFFFFFFF
25,CC,8,True,FFFFFFFFFFFFFFFF
25,CD,8,True,FFFFFFFFFFFFFFFF
25,CE,8,True,FFFFFFFFFFFFFFFF
25,CF,8,True,FFFFFFFFFFFFFFFF
25,D0,8,True,FFFFFFFFFFFFFFFF
25,D1,8,True,FFFFFFFFFFFFFFFF
25,D2,8,True,FFFFFFFFFFFFFFFF
25,D3,8,True,FFFFFFFFFFFFFFFF
25,D4,8,True,FFFFFFFFFFFFFFFF
25,D5,8,True,FFFFFFFFFFFFFFFF
25,D6,8,True,FFFFFFFFFFFFFFFF
25,D7,8,True,FFFFFFFFFFFFFFFF
25,D8,8,True,FFFFFFFFFFFFFFFF
25,D9,8,True,FFFFFFFFFFFFFFFF
25,DA,8,True,FFFFFFFFFFFFFFFF
25,DB,8,True,FFFFFFFFFFFFFFFF
25,DC,8,True,FFFFFFFFFFFFFFFF
25,DD,8,True,FFFFFFFFFFFFFFFF
25,DE,8,True,FFFFFFFFFFFFFFFF
25,DF,8,True,FFFFFFFFFFFFFFFF
25,E0,8,True,FFFFFFFFFFFFFFFF
25,E1,8,True,FFFFFFFFFFFFFFFF
25,E2,8,True,FFFFFFFFFFFFFFFF
25,E3,8,True,FFFFFFFFFFFFFFFF
25,E4,8,True,FFFFFFFFFFFFFFFF
25,E5,8,True,FFFFFFFFFFFFFFFF
25,E6,8,True,FFFFFFFFFFFFFFFF
25,E7,8,True,FFFFFFFFFFFFFFFF
25,E8,8,True,FFFFFFFFFFFFFFFF
25,E9,8,True,FFFFFFFFFFFFFFFF
25,EA,8,True,FFFFFFFFFFFFFFFF
25,EB,8,True,FFFFFFFFFFFFFFFF
25,EC,8,True,FFFFFFFFFFFFFFFF
25,ED,8,True,FFFFFFFFFFFFFFFF
25,EE,8,True,FFFFFFFFFFFFFFFF
25,EF,8,True,FFFFFFFFFFFFFFFF
25,F0,8,True,FFFFFFFFFFFFFFFF
25,F1,8,True,FFFFFFFFFFFFFFFF
25,F2,8,True,FFFFFFFFFFFFFFFF
25,F3,8,True,FFFFFFFFFFFFFFFF
25,F4,8,True,FFFFFFFFFFFFFFFF
25,F5,8,True,FFFFFFFFFFFFFFFF
25,F6,8,True,FFFFFFFFFFFFFFFF
25,F7,8,True,FFFFFFFFFFFFFFFF
25,F8,8,True,FFFFFFFFFFFFFFFF
25,F9,8,True,FFFFFFFFFFFFFFFF
25,FA,8,True,29FFFFFFFFFFFFFF
25,FB,8,True,1B29FFFFFFFFFFFF
25,FC,8,True,0F1B29FFFFFFFFFF
25,FD,8,True,130F1B29FFFFFFFF
25,FE,8,True,99130F1B29FFFFFF
25,FF,8,True,9999130F1B29FFFF[/spoiler]
i cant find any information on the datasheets to help me solve this problem, if nothing can be achieved i will have to manually control the chip with the VMOD headers.
P.S - can i get an invite link to the discord, much appreciated
Hello,
BR,
Jon
Bus=1
AddressList=4F
4F,00,1,True,1C
4F,01,1,True,00
4F,02,1,True,00
4F,03,1,True,00
4F,04,1,True,00
4F,05,1,True,00
4F,06,1,True,00
4F,07,1,True,00
4F,08,1,True,00
4F,09,1,True,00
4F,0A,1,True,00
4F,0B,1,True,00
4F,0C,1,True,00
4F,0D,1,True,00
4F,0E,1,True,00
4F,0F,1,True,00
4F,10,1,True,00
4F,11,1,True,58
4F,12,1,True,00
4F,13,1,True,5C
4F,14,1,True,40
4F,15,1,True,00
4F,16,1,True,00
4F,17,1,True,00
4F,18,1,True,00
4F,19,1,True,00
4F,1A,1,True,00
4F,1B,1,True,00
4F,1C,1,True,00
4F,1D,1,True,00
4F,1E,1,True,00
4F,1F,1,True,00
4F,20,1,True,00
4F,21,1,True,00
4F,22,1,True,00
4F,23,1,True,00
4F,24,1,True,00
4F,25,1,True,00
4F,26,1,True,00
4F,27,1,True,00
4F,28,1,True,00
4F,29,1,True,00
4F,2A,1,True,00
4F,2B,1,True,00
4F,2C,1,True,00
4F,2D,1,True,00
4F,2E,1,True,00
4F,2F,1,True,00
4F,30,1,True,00
4F,31,1,True,00
4F,32,1,True,00
4F,33,1,True,00
4F,34,1,True,00
4F,35,1,True,00
4F,36,1,True,00
4F,37,1,True,00
4F,38,1,True,00
4F,39,1,True,00
4F,3A,1,True,00
4F,3B,1,True,00
4F,3C,1,True,00
4F,3D,1,True,00
4F,3E,1,True,00
4F,3F,1,True,00
4F,40,1,True,00
4F,41,1,True,00
4F,42,1,True,00
4F,43,1,True,00
4F,44,1,True,00
4F,45,1,True,00
4F,46,1,True,00
4F,47,1,True,00
4F,48,1,True,80
4F,49,1,True,00
4F,4A,1,True,00
4F,4B,1,True,00
4F,4C,1,True,00
4F,4D,1,True,00
4F,4E,1,True,00
4F,4F,1,True,00
4F,50,1,True,04
4F,51,1,True,04
4F,52,1,True,04
4F,53,1,True,04
4F,54,1,True,04
4F,55,1,True,04
4F,56,1,True,04
4F,57,1,True,04
4F,58,1,True,04
4F,59,1,True,04
4F,5A,1,True,04
4F,5B,1,True,04
4F,5C,1,True,04
4F,5D,1,True,04
4F,5E,1,True,04
4F,5F,1,True,04
4F,60,1,True,9A
4F,61,1,True,A1
4F,62,1,True,DE
4F,63,1,True,10
4F,64,1,True,82
4F,65,1,True,24
4F,66,1,True,DA
4F,67,1,True,19
4F,68,1,True,53
4F,69,1,True,16
4F,6A,1,True,05
4F,6B,1,True,00
4F,6C,1,True,00
4F,6D,1,True,00
4F,6E,1,True,00
4F,6F,1,True,00
4F,70,1,True,00
4F,71,1,True,00
4F,72,1,True,00
4F,73,1,True,5E
4F,74,1,True,00
4F,75,1,True,00
4F,76,1,True,00
4F,77,1,True,00
4F,78,1,True,00
4F,79,1,True,00
4F,7A,1,True,00
4F,7B,1,True,00
4F,7C,1,True,00
4F,7D,1,True,00
4F,7E,1,True,00
4F,7F,1,True,00
4F,80,1,True,00
4F,81,1,True,00
4F,82,1,True,00
4F,83,1,True,00
4F,84,1,True,00
4F,85,1,True,00
4F,86,1,True,00
4F,87,1,True,00
4F,88,1,True,00
4F,89,1,True,00
4F,8A,1,True,00
4F,8B,1,True,00
4F,8C,1,True,00
4F,8D,1,True,00
4F,8E,1,True,00
4F,8F,1,True,00
4F,90,1,True,00
4F,91,1,True,00
4F,92,1,True,00
4F,93,1,True,00
4F,94,1,True,00
4F,95,1,True,00
4F,96,1,True,00
4F,97,1,True,00
4F,98,1,True,00
4F,99,1,True,00
4F,9A,1,True,00
4F,9B,1,True,00
4F,9C,1,True,00
4F,9D,1,True,00
4F,9E,1,True,00
4F,9F,1,True,00
4F,A0,1,True,00
4F,A1,1,True,00
4F,A2,1,True,00
4F,A3,1,True,00
4F,A4,1,True,00
4F,A5,1,True,00
4F,A6,1,True,00
4F,A7,1,True,00
4F,A8,1,True,00
4F,A9,1,True,00
4F,AA,1,True,00
4F,AB,1,True,00
4F,AC,1,True,00
4F,AD,1,True,00
4F,AE,1,True,00
4F,AF,1,True,00
4F,B0,1,True,00
4F,B1,1,True,00
4F,B2,1,True,00
4F,B3,1,True,00
4F,B4,1,True,00
4F,B5,1,True,00
4F,B6,1,True,00
4F,B7,1,True,00
4F,B8,1,True,00
4F,B9,1,True,00
4F,BA,1,True,00
4F,BB,1,True,00
4F,BC,1,True,00
4F,BD,1,True,00
4F,BE,1,True,00
4F,BF,1,True,00
4F,C0,1,True,00
4F,C1,1,True,00
4F,C2,1,True,00
4F,C3,1,True,00
4F,C4,1,True,00
4F,C5,1,True,00
4F,C6,1,True,00
4F,C7,1,True,00
4F,C8,1,True,00
4F,C9,1,True,00
4F,CA,1,True,00
4F,CB,1,True,00
4F,CC,1,True,00
4F,CD,1,True,00
4F,CE,1,True,00
4F,CF,1,True,00
4F,D0,1,True,00
4F,D1,1,True,00
4F,D2,1,True,00
4F,D3,1,True,00
4F,D4,1,True,00
4F,D5,1,True,00
4F,D6,1,True,00
4F,D7,1,True,00
4F,D8,1,True,00
4F,D9,1,True,00
4F,DA,1,True,00
4F,DB,1,True,00
4F,DC,1,True,00
4F,DD,1,True,00
4F,DE,1,True,00
4F,DF,1,True,00
4F,E0,1,True,00
4F,E1,1,True,00
4F,E2,1,True,00
4F,E3,1,True,00
4F,E4,1,True,00
4F,E5,1,True,00
4F,E6,1,True,00
4F,E7,1,True,00
4F,E8,1,True,00
4F,E9,1,True,00
4F,EA,1,True,00
4F,EB,1,True,00
4F,EC,1,True,00
4F,ED,1,True,00
4F,EE,1,True,00
4F,EF,1,True,00
4F,F0,1,True,00
4F,F1,1,True,00
4F,F2,1,True,00
4F,F3,1,True,00
4F,F4,1,True,00
4F,F5,1,True,00
4F,F6,1,True,00
4F,F7,1,True,00
4F,F8,1,True,00
4F,F9,1,True,00
4F,FA,1,True,00
4F,FB,1,True,00
4F,FC,1,True,00
4F,FD,1,True,10
4F,FE,1,True,DE
4F,FF,1,True,01
Bus=1
AddressList=25
Uploaded files:Quote from elmor on 2021-08-28, 07:14Quote from dragon23367 on 2021-08-19, 15:37Hello,
BR,
Bus=1
4F,00,1,True,1C
4F,01,1,True,00
4F,02,1,True,00
4F,03,1,True,00
4F,04,1,True,00
4F,05,1,True,00
4F,06,1,True,00
4F,07,1,True,00
4F,08,1,True,00
4F,09,1,True,00
4F,0A,1,True,00
4F,0B,1,True,00
4F,0C,1,True,00
4F,0D,1,True,00
4F,0E,1,True,00
4F,0F,1,True,00
4F,10,1,True,00
4F,11,1,True,58
4F,12,1,True,00
4F,13,1,True,5C
4F,14,1,True,40
4F,15,1,True,00
4F,16,1,True,00
4F,17,1,True,00
4F,18,1,True,00
4F,19,1,True,00
4F,1A,1,True,00
4F,1B,1,True,00
4F,1C,1,True,00
4F,1D,1,True,00
4F,1E,1,True,00
4F,1F,1,True,00
4F,20,1,True,00
4F,21,1,True,00
4F,22,1,True,00
4F,23,1,True,00
4F,24,1,True,00
4F,25,1,True,00
4F,26,1,True,00
4F,27,1,True,00
4F,28,1,True,00
4F,29,1,True,00
4F,2A,1,True,00
4F,2B,1,True,00
4F,2C,1,True,00
4F,2D,1,True,00
4F,2E,1,True,00
4F,2F,1,True,00
4F,30,1,True,00
4F,31,1,True,00
4F,32,1,True,00
4F,33,1,True,00
4F,34,1,True,00
4F,35,1,True,00
4F,36,1,True,00
4F,37,1,True,00
4F,38,1,True,00
4F,39,1,True,00
4F,3A,1,True,00
4F,3B,1,True,00
4F,3C,1,True,00
4F,3D,1,True,00
4F,3E,1,True,00
4F,3F,1,True,00
4F,40,1,True,00
4F,41,1,True,00
4F,42,1,True,00
4F,43,1,True,00
4F,44,1,True,00
4F,45,1,True,00
4F,46,1,True,00
4F,47,1,True,00
4F,48,1,True,80
4F,49,1,True,00
4F,4A,1,True,00
4F,4B,1,True,00
4F,4C,1,True,00
4F,4D,1,True,00
4F,4E,1,True,00
4F,4F,1,True,00
4F,50,1,True,04
4F,51,1,True,04
4F,52,1,True,04
4F,53,1,True,04
4F,54,1,True,04
4F,55,1,True,04
4F,56,1,True,04
4F,57,1,True,04
4F,58,1,True,04
4F,59,1,True,04
4F,5A,1,True,04
4F,5B,1,True,04
4F,5C,1,True,04
4F,5D,1,True,04
4F,5E,1,True,04
4F,5F,1,True,04
4F,60,1,True,9A
4F,61,1,True,A1
4F,62,1,True,DE
4F,63,1,True,10
4F,64,1,True,82
4F,65,1,True,24
4F,66,1,True,DA
4F,67,1,True,19
4F,68,1,True,53
4F,69,1,True,16
4F,6A,1,True,05
4F,6B,1,True,00
4F,6C,1,True,00
4F,6D,1,True,00
4F,6E,1,True,00
4F,6F,1,True,00
4F,70,1,True,00
4F,71,1,True,00
4F,72,1,True,00
4F,73,1,True,5E
4F,74,1,True,00
4F,75,1,True,00
4F,76,1,True,00
4F,77,1,True,00
4F,78,1,True,00
4F,79,1,True,00
4F,7A,1,True,00
4F,7B,1,True,00
4F,7C,1,True,00
4F,7D,1,True,00
4F,7E,1,True,00
4F,7F,1,True,00
4F,80,1,True,00
4F,81,1,True,00
4F,82,1,True,00
4F,83,1,True,00
4F,84,1,True,00
4F,85,1,True,00
4F,86,1,True,00
4F,87,1,True,00
4F,88,1,True,00
4F,89,1,True,00
4F,8A,1,True,00
4F,8B,1,True,00
4F,8C,1,True,00
4F,8D,1,True,00
4F,8E,1,True,00
4F,8F,1,True,00
4F,90,1,True,00
4F,91,1,True,00
4F,92,1,True,00
4F,93,1,True,00
4F,94,1,True,00
4F,95,1,True,00
4F,96,1,True,00
4F,97,1,True,00
4F,98,1,True,00
4F,99,1,True,00
4F,9A,1,True,00
4F,9B,1,True,00
4F,9C,1,True,00
4F,9D,1,True,00
4F,9E,1,True,00
4F,9F,1,True,00
4F,A0,1,True,00
4F,A1,1,True,00
4F,A2,1,True,00
4F,A3,1,True,00
4F,A4,1,True,00
4F,A5,1,True,00
4F,A6,1,True,00
4F,A7,1,True,00
4F,A8,1,True,00
4F,A9,1,True,00
4F,AA,1,True,00
4F,AB,1,True,00
4F,AC,1,True,00
4F,AD,1,True,00
4F,AE,1,True,00
4F,AF,1,True,00
4F,B0,1,True,00
4F,B1,1,True,00
4F,B2,1,True,00
4F,B3,1,True,00
4F,B4,1,True,00
4F,B5,1,True,00
4F,B6,1,True,00
4F,B7,1,True,00
4F,B8,1,True,00
4F,B9,1,True,00
4F,BA,1,True,00
4F,BB,1,True,00
4F,BC,1,True,00
4F,BD,1,True,00
4F,BE,1,True,00
4F,BF,1,True,00
4F,C0,1,True,00
4F,C1,1,True,00
4F,C2,1,True,00
4F,C3,1,True,00
4F,C4,1,True,00
4F,C5,1,True,00
4F,C6,1,True,00
4F,C7,1,True,00
4F,C8,1,True,00
4F,C9,1,True,00
4F,CA,1,True,00
4F,CB,1,True,00
4F,CC,1,True,00
4F,CD,1,True,00
4F,CE,1,True,00
4F,CF,1,True,00
4F,D0,1,True,00
4F,D1,1,True,00
4F,D2,1,True,00
4F,D3,1,True,00
4F,D4,1,True,00
4F,D5,1,True,00
4F,D6,1,True,00
4F,D7,1,True,00
4F,D8,1,True,00
4F,D9,1,True,00
4F,DA,1,True,00
4F,DB,1,True,00
4F,DC,1,True,00
4F,DD,1,True,00
4F,DE,1,True,00
4F,DF,1,True,00
4F,E0,1,True,00
4F,E1,1,True,00
4F,E2,1,True,00
4F,E3,1,True,00
4F,E4,1,True,00
4F,E5,1,True,00
4F,E6,1,True,00
4F,E7,1,True,00
4F,E8,1,True,00
4F,E9,1,True,00
4F,EA,1,True,00
4F,EB,1,True,00
4F,EC,1,True,00
4F,ED,1,True,00
4F,EE,1,True,00
4F,EF,1,True,00
4F,F0,1,True,00
4F,F1,1,True,00
4F,F2,1,True,00
4F,F3,1,True,00
4F,F4,1,True,00
4F,F5,1,True,00
4F,F6,1,True,00
4F,F7,1,True,00
4F,F8,1,True,00
4F,F9,1,True,00
4F,FA,1,True,00
4F,FB,1,True,00
4F,FC,1,True,00
4F,FD,1,True,10
4F,FE,1,True,DE
[spoiler title=""]
Bus=1
Link for Discord is at the top of the page (icon furthest to the left, before twitter).
In order to clear the lock you may need to completely remove power to the card, including standby power. After that you can either try to shorten the pins or you can try the bus lock feature of EVC2. Normally the lock will happen during the POST process before there's any display output.
BR,
3070ti i2c dumpEVC2 1.0.1.7 I2C DUMP
Bus=1
4F,00,1,True,1C
4F,01,1,True,00
4F,02,1,True,00
4F,03,1,True,00
4F,04,1,True,00
4F,05,1,True,00
4F,06,1,True,00
4F,07,1,True,00
4F,08,1,True,00
4F,09,1,True,00
4F,0A,1,True,00
4F,0B,1,True,00
4F,0C,1,True,00
4F,0D,1,True,00
4F,0E,1,True,00
4F,0F,1,True,00
4F,10,1,True,00
4F,11,1,True,58
4F,12,1,True,00
4F,13,1,True,5C
4F,14,1,True,40
4F,15,1,True,00
4F,16,1,True,00
4F,17,1,True,00
4F,18,1,True,00
4F,19,1,True,00
4F,1A,1,True,00
4F,1B,1,True,00
4F,1C,1,True,00
4F,1D,1,True,00
4F,1E,1,True,00
4F,1F,1,True,00
4F,20,1,True,00
4F,21,1,True,00
4F,22,1,True,00
4F,23,1,True,00
4F,24,1,True,00
4F,25,1,True,00
4F,26,1,True,00
4F,27,1,True,00
4F,28,1,True,00
4F,29,1,True,00
4F,2A,1,True,00
4F,2B,1,True,00
4F,2C,1,True,00
4F,2D,1,True,00
4F,2E,1,True,00
4F,2F,1,True,00
4F,30,1,True,00
4F,31,1,True,00
4F,32,1,True,00
4F,33,1,True,00
4F,34,1,True,00
4F,35,1,True,00
4F,36,1,True,00
4F,37,1,True,00
4F,38,1,True,00
4F,39,1,True,00
4F,3A,1,True,00
4F,3B,1,True,00
4F,3C,1,True,00
4F,3D,1,True,00
4F,3E,1,True,00
4F,3F,1,True,00
4F,40,1,True,00
4F,41,1,True,00
4F,42,1,True,00
4F,43,1,True,00
4F,44,1,True,00
4F,45,1,True,00
4F,46,1,True,00
4F,47,1,True,00
4F,48,1,True,80
4F,49,1,True,00
4F,4A,1,True,00
4F,4B,1,True,00
4F,4C,1,True,00
4F,4D,1,True,00
4F,4E,1,True,00
4F,4F,1,True,00
4F,50,1,True,04
4F,51,1,True,04
4F,52,1,True,04
4F,53,1,True,04
4F,54,1,True,04
4F,55,1,True,04
4F,56,1,True,04
4F,57,1,True,04
4F,58,1,True,04
4F,59,1,True,04
4F,5A,1,True,04
4F,5B,1,True,04
4F,5C,1,True,04
4F,5D,1,True,04
4F,5E,1,True,04
4F,5F,1,True,04
4F,60,1,True,9A
4F,61,1,True,A1
4F,62,1,True,DE
4F,63,1,True,10
4F,64,1,True,82
4F,65,1,True,24
4F,66,1,True,DA
4F,67,1,True,19
4F,68,1,True,53
4F,69,1,True,16
4F,6A,1,True,05
4F,6B,1,True,00
4F,6C,1,True,00
4F,6D,1,True,00
4F,6E,1,True,00
4F,6F,1,True,00
4F,70,1,True,00
4F,71,1,True,00
4F,72,1,True,00
4F,73,1,True,5E
4F,74,1,True,00
4F,75,1,True,00
4F,76,1,True,00
4F,77,1,True,00
4F,78,1,True,00
4F,79,1,True,00
4F,7A,1,True,00
4F,7B,1,True,00
4F,7C,1,True,00
4F,7D,1,True,00
4F,7E,1,True,00
4F,7F,1,True,00
4F,80,1,True,00
4F,81,1,True,00
4F,82,1,True,00
4F,83,1,True,00
4F,84,1,True,00
4F,85,1,True,00
4F,86,1,True,00
4F,87,1,True,00
4F,88,1,True,00
4F,89,1,True,00
4F,8A,1,True,00
4F,8B,1,True,00
4F,8C,1,True,00
4F,8D,1,True,00
4F,8E,1,True,00
4F,8F,1,True,00
4F,90,1,True,00
4F,91,1,True,00
4F,92,1,True,00
4F,93,1,True,00
4F,94,1,True,00
4F,95,1,True,00
4F,96,1,True,00
4F,97,1,True,00
4F,98,1,True,00
4F,99,1,True,00
4F,9A,1,True,00
4F,9B,1,True,00
4F,9C,1,True,00
4F,9D,1,True,00
4F,9E,1,True,00
4F,9F,1,True,00
4F,A0,1,True,00
4F,A1,1,True,00
4F,A2,1,True,00
4F,A3,1,True,00
4F,A4,1,True,00
4F,A5,1,True,00
4F,A6,1,True,00
4F,A7,1,True,00
4F,A8,1,True,00
4F,A9,1,True,00
4F,AA,1,True,00
4F,AB,1,True,00
4F,AC,1,True,00
4F,AD,1,True,00
4F,AE,1,True,00
4F,AF,1,True,00
4F,B0,1,True,00
4F,B1,1,True,00
4F,B2,1,True,00
4F,B3,1,True,00
4F,B4,1,True,00
4F,B5,1,True,00
4F,B6,1,True,00
4F,B7,1,True,00
4F,B8,1,True,00
4F,B9,1,True,00
4F,BA,1,True,00
4F,BB,1,True,00
4F,BC,1,True,00
4F,BD,1,True,00
4F,BE,1,True,00
4F,BF,1,True,00
4F,C0,1,True,00
4F,C1,1,True,00
4F,C2,1,True,00
4F,C3,1,True,00
4F,C4,1,True,00
4F,C5,1,True,00
4F,C6,1,True,00
4F,C7,1,True,00
4F,C8,1,True,00
4F,C9,1,True,00
4F,CA,1,True,00
4F,CB,1,True,00
4F,CC,1,True,00
4F,CD,1,True,00
4F,CE,1,True,00
4F,CF,1,True,00
4F,D0,1,True,00
4F,D1,1,True,00
4F,D2,1,True,00
4F,D3,1,True,00
4F,D4,1,True,00
4F,D5,1,True,00
4F,D6,1,True,00
4F,D7,1,True,00
4F,D8,1,True,00
4F,D9,1,True,00
4F,DA,1,True,00
4F,DB,1,True,00
4F,DC,1,True,00
4F,DD,1,True,00
4F,DE,1,True,00
4F,DF,1,True,00
4F,E0,1,True,00
4F,E1,1,True,00
4F,E2,1,True,00
4F,E3,1,True,00
4F,E4,1,True,00
4F,E5,1,True,00
4F,E6,1,True,00
4F,E7,1,True,00
4F,E8,1,True,00
4F,E9,1,True,00
4F,EA,1,True,00
4F,EB,1,True,00
4F,EC,1,True,00
4F,ED,1,True,00
4F,EE,1,True,00
4F,EF,1,True,00
4F,F0,1,True,00
4F,F1,1,True,00
4F,F2,1,True,00
4F,F3,1,True,00
4F,F4,1,True,00
4F,F5,1,True,00
4F,F6,1,True,00
4F,F7,1,True,00
4F,F8,1,True,00
4F,F9,1,True,00
4F,FA,1,True,00
4F,FB,1,True,00
4F,FC,1,True,00
4F,FD,1,True,10
4F,FE,1,True,DE
4F,FF,1,True,01i tried to manually add the UP9512, no controllers was found on all address', i knew it wouldnt of been that easy so i located the SDA, SDL, GND mouting points next to the controller itself.
SpoilerEVC2 1.0.1.7 I2C DUMP
Bus=1
25,FF,8,True,9999130F1B29FFFFi cant find any information on the datasheets to help me solve this problem, if nothing can be achieved i will have to manually control the chip with the VMOD headers.
