EVC2SX can't see offset to change voltage
Quote from wael kanakri on 2022-11-22, 01:44Hello, I'm trying to voltmod my 4090 strix using the EVC2SX. I don't seem to have the vout offset option to change the voltage. Any ideas what can be causing this problem
Quote from elmor on 2022-11-22, 19:51Quote from wael kanakri on 2022-11-22, 01:44Hello, I'm trying to voltmod my 4090 strix using the EVC2SX. I don't seem to have the vout offset option to change the voltage. Any ideas what can be causing this problem
Hello, before there was only a test release to add support for MP2891. I've uploaded the official version 1.0.1.13 here which supports it: https://www.elmorlabs.com/forum/topic/evc2-beta-software/
Quote from wael kanakri on 2022-11-22, 21:05Quote from elmor on 2022-11-22, 19:51Quote from wael kanakri on 2022-11-22, 01:44Hello, I'm trying to voltmod my 4090 strix using the EVC2SX. I don't seem to have the vout offset option to change the voltage. Any ideas what can be causing this problem
Super, thank you for the prompt action on this. I'm from a youtube channel in the middle east called CAMBOTAR
Hopefully we can rank up on port royal with the voltmod. +1000w bios. Currently we are ranked 6th on port royal and 6th as well on TimeSpy Extreme GPU (both under Cambotar)
Port Royal
https://www.3dmark.com/hall-of-fame-2/port+royal+3dmark+score+performance+preset/version+1.0/1+gpu
TimeSpy Extreme GPU
https://www.3dmark.com/hall-of-fame-2/timespy+graphics+score+extreme+preset/version+1.0/1+gpu
Any idea when is the heater coming back to stock as well as the pads ?
Cheers
Dark
Port Royal
Port Royal
TimeSpy Extreme GPU
Cheers
Dark
Port Royal
