2025-08-02: Please check here for a PCIe 5.0 compatible adapter https://www.elmorlabs.com/product/adt-link-r33g-pci-e-5-0-slot-power-measurement-adapter-for-pmd/
2025-01-15: New revision 05 now shipping with optional 3.3V power measurement
PMD-AD-P4X16-05 (new revision)
In order for the PMD product to be able to measure the full power consumption of a graphics card it’s also necessary to account for the power provided through the PCI-E slot. Therefore we’ve created this PCI-E adapter card that allows you to provide the slot power from an external source through a 6-pin PCIe connector. The adapter is rated for PCI-E 4.0 (x16 lanes at Gen 4 speeds). It also has an on-board regulator for the 3.3V and 3.3VA rails in order to include these rails in the external power measurement.
PMD-AD-P4X16-04 (old revision)
In order for the PMD product to be able to measure the full power consumption of a graphics card it’s also necessary to account for the power provided through the PCI-E slot. Therefore we’ve created this PCI-E adapter card that allows you to provide the slot 12V power from an external source through a 4-pin CPU/EPS connector such as the two EPS cables bundled with PMD. The adapter is rated for PCI-E 4.0 (x16 lanes at Gen 4 speeds).
Accessories
- 4-pin male to 4-pin EPS female 20 cm AWG18 black cable (old revision only)
