RX5700XT Liquid Devil
Quote from xtremefunky on 2022-05-07, 05:47All right, thank you for your help.
Side question: is this firmware Safe to use? Or should I flash back to an other one?
Quote from xtremefunky on 2022-05-10, 22:35maybe.... anything new?
Quote from xtremefunky on 2022-11-22, 20:50Today I tried again and I have some success and not.
The thing is. If I manually add the IR35217 (I²C and PMBus) I get kind of reading
and offsets. Nothing to crazy. And very rigged and bugged.
Cant adjust anything. But at least it gets a kind of connection.
Can we maybe work from there?
It also doesnt work everytime. I have to short it at the start and then I can hook kinda into.
Quote from elmor on 2022-11-22, 21:17Quote from xtremefunky on 2022-11-22, 20:50Today I tried again and I have some success and not.
It also doesnt work everytime. I have to short it at the start and then I can hook kinda into.Hi, you can start with testing latest SW and FW (IIRC you have EVC2N4?) Which was recently updated. Would be helpful to show what it looks like after device scan afterwards.
https://www.elmorlabs.com/forum/topic/evc2-beta-software/
https://www.elmorlabs.com/forum/topic/evc2-beta-firmware/
Quote from xtremefunky on 2022-11-22, 21:57Thanks for the fast reply!
I did and this was the outcome:Im kinda confused now.
Quote from xtremefunky on 2022-11-22, 23:39As it turns out, the IR35217 isnt connected to the nearby header.
Only the VReg for the memory is.
I found the solder pad for the I²C nearby the Chip and I wanted to connect the cable to it.
Unfortunately I ripped the pad off the PCB and it appears this should be it for the
"Elmor EVC" action on this card. Sad!
