EVC2 Beta Firmware
Quote from elmor on 2023-11-30, 19:11Quote from Jonathan Kurz on 2023-10-29, 00:06So Im having the same issue as the guy above. When I point the STM32 bootloader into the driver folder, it says correct driver installed.
When I unplug move the jumper the EVC show as a microelectronics device.
Any suggestion? Im just lost!
Hello, are you able to use the driver included in STM32CubeProgrammer? If you select Update driver -> Select manually and go to path "C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\Drivers\DFU_Driver\Driver"?
Quote from HueSplat on 2023-12-26, 22:15Hey, hope you are going well. I have a EVC2SX-03 STM32F072C, was trying to update the firmware on it.
I can't seem to get STM32CubeProgrammer to work with the correct driver installed, latest version 2.15, it will not connect, I get the error message "device is under read out protection", checking "Read Unprotect" does not help.
Tried a Win10 PC as well as my Win11 laptop and i get the same error on both.DfuSe works fine, was able to flash 0009d (F0) dfu, detects and works in the EVC software.
Am I doing something wrong?
